Signal not flashing
Eljeef
Post by Eljeef » Thu May 05, 2016 11:25 am
Thanks Graham. I learned that through necessity and the tutelage of Jensen.
1964-C77 305 Dream
2002 BMW R1150GS
Robbie63
Post by Robbie63 » Fri May 06, 2016 12:52 pm
I took apart the flasher and cleaned the points inside. This did not fix my problem.not sure what to do to the flasher any thoughts on what else I can do would be appreciated.i used a flasher off my xt 350 but did not work only lite up the signals.....rob
Eljeef
Post by Eljeef » Tue May 10, 2016 12:23 pm
There is a diode in the base. Get it tested. You can hook up a modern flasher to see if things work. Check your ground.
1964-C77 305 Dream
2002 BMW R1150GS
Robbie63
Post by Robbie63 » Thu May 12, 2016 10:32 am
I picked up another flasher Canadian tire,installed it and it works great.Thanks for all the input.the 12 volt system works a lot better than 6 volt as what's in my baby benly.??
