Cam Chain Tensioner Roller Refurb or replacement
Post by G-Man » Tue Jul 12, 2016 11:31 am
Well I finally got back to the Kawasaki Idler conversion idea. I took a few measurements and discovered that there is a bearing that will fit the idler gear and is a match for the 12mm center bush out of the small wheel tensioners.
It was a simple job to press out the old bearing (which I made a bit of a mess of in my haste) and press in a new one with a larger ID. The new one is a 12x16x14mm drawn cup needle roller.
It was simple (for me anyway) to do my usual modifications to the center pin (drill and tap for M7), make a clearance hole in the slotted end for my M7 bolt and just put the parts together.
It went together far too easily......
I really like this Kawasaki part because of the intelligent use of rubber cushioning with the wear resistance of a steel part.
It should be quite quiet in operation. It just makes me smile that this could be achieved with a minimum of effort...... :-)
I just ordered some M12 shim washers to take up the side clearance between wheel and tensioner arm and that should be all finished.
Geoff Hastings
Cam chain tensioner modification
Post by Geoff Hastings » Wed Feb 22, 2017 5:46 pm
I'm currently restoring a ca77 and the tensioner is quite worn, is there a part number for the toothed Kawasaki idler sprocket used in the modification?
Post by G-Man » Fri Feb 24, 2017 12:31 pm
Geoff
New ones are prohibitively expensive. Just look out for Z650 or Z1 / Z900 cam chain idlers.
http://www.ebay.com/itm/1978-KAWASAKI-K ... O2&vxp=mtr
Geoff Hastings
Post by Geoff Hastings » Fri Feb 24, 2017 1:01 pm
G-Man wrote:Geoff
Thanks for the info, you are quite right, new ones are really expensive. Also, has anyone found a substitute for the chain guard? I've bought one for a 125 Honda that looks like I can adapt it but would prefer something a bit closer to the original.
Geoff
Post by G-Man » Fri Feb 24, 2017 1:05 pm
Geoff
The Dream chain guard comes up on eBay from time to time. Like all tin parts though, they can be expensive.
http://www.ebay.com/sch/i.html?_from=R4 ... d&_sacat=0
pemdoc65
Post by pemdoc65 » Tue Feb 28, 2017 1:41 pm
Where did you source the new bearing that you installed? This looks like an interesting upgrade for some of the worn out tensioners that I have lying around.
Post by G-Man » Tue Feb 28, 2017 4:38 pm
Here you go. They do ship to the US, if required.
http://simplybearings.co.uk/shop/Bearin ... index.html
