67' CB77 oil leak behind stator
Post by LOUD MOUSE » Sun Jan 21, 2018 8:40 am
Find a sharp pointed something and go to the outer edge and tap through the rubber near the outer edge and pray out. .............lm
I may be wrong but I think that is what I recommended. .................lm
oldbikedude wrote:I think you need to get behind the metal and pry it out.
AlanW
Post by AlanW » Sun Jan 21, 2018 8:59 am
You are correct as usual LM, that should work.
Al.
Re: Rotor removal,
Post by LOUD MOUSE » Sun Jan 21, 2018 9:34 am
The seal HONDA used is the 32/65/6.5.
Not to worry about the tab as it was to hold the seal in place with the upper case until the lower case waas installed. .................lm
DesertSilo wrote:The seal I have shows 32 / 65 / 6.5 the one in the bike is 32 / 65 / 7.5 is that going to be an issues? Looks like the replacement lip is slightly larger than the gap.
Also after using an exacto knife around the entire edge still stuck in there good. Going to be a slow process of digging it out. looks like who ever installed it used sealant on both the inside and outside lip causing it to crumble at the slightest yank or pry......
https://imgur.com/zxgR5fP
before
https://imgur.com/GIrJHjz
-Geoff
LOUD MOUSE wrote:It has a metal plate on the engine side.
DesertSilo wrote:Any recommendations on removing the old right crankshaft seal (not the sprocket seal)? seems to be pretty dang stuck in there and the lip seems to crumble when trying to pry it out. there looks to be a small metal plate behind the rubber gasket is that removable?
DesertSilo
Post by DesertSilo » Sun Jan 21, 2018 5:51 pm
Here are some pictures after spending three hours today trying to pry the rubber bits out. Only thing small enough to fit between the metal is an exacto knife. (Ruined a pair of fine nose tweezers, a pick set wont fit, small flat head isn't long enough, and various other sharp pointed things arnt strong enough and bend / break.) Heat gun also seems to have no effect on the rubber with making it more pliable or easier to get out.
https://imgur.com/UQXMe18
And for some reason, the gap seems way smaller than the replacement seal? Is this standard or will I have to look into countersunk drilling options?
https://imgur.com/LXZKWPg
After reading quite a few threads on seal removals, I havn't see much trouble getting the seal out its more getting the seal in.
Any other options before I start looking for a mechanic to send the bike off to?
Thanks! -Geoff
LOUD MOUSE wrote:Find a sharp pointed something and go to the outer edge and tap through the rubber near the outer edge and pray out. .............lm
AlanW
Post by AlanW » Sun Jan 21, 2018 6:21 pm
You need to punch through the seal on it's face maybe a couple of mm from the outer edge and lever it out using the ally case as a fulcrum, as lm told you. You should never insert anything down the edge of the seal.
I fear you may have damaged the seat the seal fits into the way you have been doing it.
Good luck with it.
Al.
Post by LOUD MOUSE » Sun Jan 21, 2018 6:23 pm
Use a sharp blade (EXACTO) to cut the outer edge at a angle then tap the new seal into the case going circular with the tool. ..................lm
DesertSilo wrote:Here are some pictures after spending three hours today trying to pry the rubber bits out. Only thing small enough to fit between the metal is an exacto knife. (Ruined a pair of fine nose tweezers, a pick set wont fit, small flat head isn't long enough, and various other sharp pointed things arnt strong enough and bend / break.) Heat gun also seems to have no effect on the rubber with making it more pliable or easier to get out.
https://imgur.com/OuVtau5
Thanks! -Geoff
DesertSilo
Post by DesertSilo » Sun Jan 21, 2018 7:19 pm
Thank you for all your help and responses, trying to make a picture from text and is difficult.
Cross section of a standard seal installed. // Outer edge being top of the rubber or edge of the lip? https://imgur.com/lhxdSoN
https://imgur.com/P9gOcIX
After removing the outer section the inner seal remains (looks glued / oil saturated).
https://imgur.com/A1ezrBm
"Cut the outer edge at an angle," do you mean like this (see link below)?
https://imgur.com/kHT7x3T
I have been cutting along the long edge around the aluminum which doesn't seem to free up the rubber. If I cut at an angle then tap the new seal in (see below picture), where does the old rubber go?
https://imgur.com/XGnZWuB
Thanks for being a big help with this. -Geoff
LOUD MOUSE wrote:Use a sharp blade (EXACTO) to cut the outer edge at a angle then tap the new seal into the case going circular with the tool. ..................lm
Thanks! -Geoff
