This is the reason (plus many folks don't have or know how to use a timing light) I have offered the simple and effective to do the "in your garage" points adjustments.
Granted I am aware that once my idea is used it can be fine tuned with a timing light as now all that is required is to adjust the plate a couple thousands.
Ever heard "your carburetor problem is in direct proportion to the miss adjustment of your points?. . . ...............lm
Tim Miller wrote:Yes, Like I said both cylinder must be the same at full advance. After you set the points @ .014 on the right side adjust the points plate till you get the total timing set between the two marks and lock it down, then check the left side and adjust only the L points gap till it reads the same as the right. Its easy.
Tim
LOUD MOUSE wrote:Do you use it to set each set while the engine is running?. ............lm
Tim Miller wrote:Yes, your advance spring maybe a little weak, but as long as the timing isn't jumping around at idle your OK. I do like to see the timing at idle as close to F as posible, but that's not always possible because of wear on the advancer stops. The most important thing for me is that the total timing at full advance say above 3500 RPM reads between the two full advance marks on both cylinders. No matter what it is idles. This is why I always use the strobe timing light. More often than not if you only set the timing for idle it will over advance the total timing at full throttle and sieze the pistons. The timing light is the cheepest insurance you can buy.
Tim
akpasta wrote:Ok, I get it. So if you could run the engine at like 500rpms it would be very close to the F mark, but when I'm idling at 1500 rpms, it's going to be a bit past the F mark.
So you use the strobe to make sure it doesn't advance too much at full advance. Is the case mark supposed to be in the middle of those two advance lines or before?
thanks.
