Thank You HT, Seadog and Loud Mouse for all the help.
Here is how I checked the cam timing today. Please tell me if I need to go back and do it by the book. Pressure builds on the left cylinder up to the point where LT passes by the pointer then it subsides after LT retreats away the pointer.
Also, I flipped the crankshaft nut over. Thanks for that too. Here is a link to a video of when I started it up prior to disassembly. It did start to run fairly decently once I got some fuel to the right side.
https://www.youtube.com/watch?v=g29gNS6g6yw
About the little washer. I barely remember on the CB160's that the washer goes behind the centrifugal filter, correct? Or does it go right behind the pin. I remember when it is in the correct position the chain lines up. I know I put it in the correct spot at the time but I just don't remember which any more.
Also, I switched the crankshaft nut, bevel side is now in. Correct LM?
And my last question for tonight is CMSNL shows the same part number for the gasket behind the tacho drive and behind the points plate. Are they the same? There were no gaskets when I looked today, just a little form a gasket type material.
Thank You for your help
Steve
