Steve
Good to see that you've got it apart. Those yellow paint marks, I think, are from the inspectors during manufacture, They are just marking that some important assembly operation or test has been done correctly.
You used to see it on critical things like brake rotor bolts on later Hondas.
It shouldn't really matter as your botoom case looks pretty clean but I take out those two steel oil separators at the front to just see if anything lurks underneath.... Anything that gets down there is pretty safe but it helps tell the story.
Steverino wrote:I had to take the motor partially apart this afternoon. I had to in order to replace those two studs that were twisted with fouled cap nuts. Maybe the guy that messed up the cam timing thought they would look nice since he had no engine cover. Seemingly innocent little "custom" touches like that sure can mess up a motor. Splitting the case gave me a chance to look inside. I checked all the way around the gears and they look good. No chips that I can see. Notice the splotch of paint on the mainshaft. I wonder what it means.
KIMG0813 by
Steve Steverinomeister, on Flickr
KIMG0841 by
I turned the rotating assemblies and they felt smooth and quiet with no rough spots. Here is kind of a picture with a glimps of bearing and race.
KIMG0823 by
Here is the bottom half and the two studs. sI found no cracks or troublesome shards of metal.
KIMG0810 by
