The rollers are loaded into the tool then it is inverted and applied to very fine abrasive paper on a smooth surface. Once half the material is removed the rollers are emptied out, turned over and the process repeated. After around 10-15 minutes the rollers all fitted nicely in my cage.
Just to make sure that all was OK a set of rollers was greased and loaded into the cage in one of my rods.
This was much simpler to do than I expected and much, much cheaper than trying to use those almost unobtainable Honda rollers.
If I am going to re-use these rods, I will have to sort out the small ends. The bore looks like it has had a hard life and I am going to experiment with putting a bronze bush in the eye. A lot easier job to do when the rods are off the crank.
