                    Electronic Ignition is Back !!!
Re: Electronic Ignition is Back !!!
Michael, is this unit still available? I have tried other means of contacting you but maybe this will work. Lol. I have a 67 CL77.Michael Stoic wrote:
This is a pre-announcement. Starting now, the Electronic Ignitions are once again available.
There will be a limited quantity of the new version of the Electronic Ignition Kits for all CB/CL 72/77 motors.
If you've been hoping to get one, please contact me by email. I will send out full details within the next few days, by email.
Thank you,
Michael Stoic
honda305.com
				WrenchRust
				Peter Handscope
ignition key
If you find yourself in a situation where your key won’t turn in the ignition of your vehicle, there are a number of issues that may be causing the problem. If the ignition cylinder has seized, spraying a small amount of electrical cleaner into the key hole may lubricate it enough to turn. Be careful not to spray too much into the key hole. A few short squirts should sufficient.
