engine oil
Re: engne oil
Post by G-Man » Mon Sep 14, 2015 2:11 am
And you're all still alive?
brewsky wrote:
G-Man wrote:Brewsky
They're still happily tidying up the mess that we all made 40 years before that......
brewsky wrote:
G-Man wrote:
I changed the oil in the corner of a field in France once on a 2000 mile vacation.....
quote]
Here's hoping the statute of limitations has passed on the violation!
Yep,
The recycling program in my neighborhood consisted of re-purposing used pcb-laden transformer oil as dust palliative on the dirt roads in front of the houses!..... GENIUS!
brewsky
Re: engne oil
Post by brewsky » Mon Sep 14, 2015 5:09 am
G-Man wrote:And you're all still alive?
quote]
Well, at least I am.......I think......although I do wonder if I'm actually in an alternative universe sometimes!
Back to the original subject, I do remember the oil debate in the '60's being Pennsylvania vs Gulf coast based oils.
I remember my chemical engineer neighbor telling me the Pennsylvania (paraffin) based oils, like Pennzoil and Quaker State were better suited for hotter-running air cooled engines, and the Gulf coast oils (Gulf, Texaco, etc) better for water cooled applications.
So the debate will probably march on for another 50 years,,,,,
................TO BE CONTINUED!
Re: engne oil
Post by G-Man » Mon Sep 14, 2015 5:21 am
Brewsky
Yes - we've had all sorts of 'discussions' over here. My Uncle swore by a graphite loaded oil by a company called Filtrate. There big thing was cold starts ( where most of the corrosion / wear happens). Not sure how that would work with modern filters.
More recently, there seems to be a flare up of problems related to synthetics and corrosion issues in two-strokes stored over winter.
I have a little theory about the copper plating that Honda used during carburizing (hardening) contributing to corrosion in cranks that have stood a long while. Copper on steel has the opposite effect to zinc and the steel becomes sacrificial.... That combined with acids from combustion suggests to me that we should 'store' our bikes with fresh oil in the sump.
Here's to the next 50 years of lively 'discussion'.
quote]
masonmart
Post by masonmart » Mon Jul 04, 2016 3:30 am
Sorry gents, I didn't mean Honda recommended changing a straight 30 grade non-detergent oil at 300 miles only if that I were to put such a relatively poor quality lubricant into my own bike on which I don't do many miles, I'd change the oil every 300 miles as all of my friends do and swear by it. I personally use classic 20W50 or the 10W40 that is recommended for my Kawasaki Z900. Seriously, monograde is not right for most temperate locations ranges and non-detergent is just not right for a bike that doesn't have a good filtration system. Modern multigrade oils are just far better than monogrades and synthetic oils are the best of all. If I did more miles and all year round I'd use a 5W30 fully synthetic because that suits the temp of the UK.
I'd guess that most change their oil at low intervals anyway so the impact of using low quality oil is low but my own policy is quality, quality, quality; not at any cost but given the small amount we put in the CB77 quality is cheap.
Best wishes
hondadreamca77
Oil
Post by hondadreamca77 » Wed Jul 06, 2016 9:15 am
Castrol 30W.....
This subject is still being discussed, really?????
68' 305 Dream, 75' Honda 750-four, 74' Honda CL 125, 72' Honda CA 70, 80' Honda Passport, 74' Aerimachi Harley Sprint 125, 64' Yamaha 90.
Post by LOUD MOUSE » Wed Jul 06, 2016 11:08 am
Would you say VALVOLINE 30W ND is LOW QUALITY?. ............lm
masonmart wrote:Sorry gents, I didn't mean Honda recommended changing a straight 30 grade non-detergent oil at 300 miles only if that I were to put such a relatively poor quality lubricant into my own bike on which I don't do many miles, I'd change the oil every 300 miles as all of my friends do and swear by it. I personally use classic 20W50 or the 10W40 that is recommended for my Kawasaki Z900. Seriously, monograde is not right for most temperate locations ranges and non-detergent is just not right for a bike that doesn't have a good filtration system. Modern multigrade oils are just far better than monogrades and synthetic oils are the best of all. If I did more miles and all year round I'd use a 5W30 fully synthetic because that suits the temp of the UK.
Best wishes
masonmart
Post by masonmart » Thu Jul 07, 2016 3:49 pm
LOUD MOUSE wrote:Would you say VALVOLINE 30W ND is LOW QUALITY?. ............lm
No LM, what I'm saying is that using mono grade oil is just a poor quality choice for any bike. Also that using a non-detergent oil is a poor quality choice and that not moving with developments in lubricant technology is a low quality choice too. The best quality choice for any bike is to use modern oils but we have to moderate our choice based on mileage, etc. The last thing we should do is use 30 grade oil because it says to do so on our 1963 bikes. The CB77 has no design features that would preclude the use of modern oils.
Best wishes, MM
