Very low compression, what to look for?
deafanddiabetic
deafanddiabetic
Well, more adventures to this story.
I realized that I had bought standard sized rings for .5 O/S pistons, so I took the engine apart to replace those.
Now that everything is back together again and adjusted, I'm dry firing about 100psi per cylinder after 5 kicks. I have not put the engine into the bike yet, but my local mechanic said that it'll probably be a little while before the rings seat into the cylinders and my compression will go up.
Man, this has been a headache.
deafanddiabetic
https://www.facebook.com/video.php?v=10 ... 2276431180
In that link is a video of it running now. I put in proper piston rings, ordered another gasket set, installed O-Rings on the two posts on the cylinder base and put new O-Rings into the tappet covers. I torqued the head to 18ft/lbs last time according to my manual. I did it to 20ft/lbs this time.
It's literally pouring out of somewhere that looks higher than the head gasket. I have no idea what to do, I'm getting pretty bummed out about this project.
Someone suggested that I might have a hairline crack in the head?
deafanddiabetic
