                    ideas on what happened?
				raindriver
measuring stick
Rain, A "wonky" measuring stick is no different than guessing.  If it is not accurate there is no way to tell what you have.  You need precise measurements to tell what to do.
						Excessive smoke
Bill Silver has a note in his 305 Engine Repair Guide on page 109.
"The intake guides are drilled with small holes which break up the 'suction effect' of the oil film on the valve stem moving in the guides. The idea was to prevent excess oil from being drawn down the guide and into the intake port. If the passages are plugged or restricted, exhaust smoke and increased oil consumption can occur. There are no valve stem seals installed in these engines. If the valve spring seats are not installed under the springs, the valve guides can work loose in the heads, as the spring seats also serve to keep the guides in place"
Something to consider, though if this is the problem I would expect the smoke to smell of burning oil.
Re: Excessive smoke
HONDA discontinued those vents on the head in 1967.
Lots of engines have them pluged with bolts or run a tubing from one to the other. ....lm
conbs wrote:Bill Silver has a note in his 305 Engine Repair Guide on page 109.
Re: Excessive smoke
LM, I take Bill's quote to refer to the valve guides themselves and not the head casting. Is he wrong?LOUD MOUSE wrote:HONDA discontinued those vents on the head in 1967.
Re: Excessive smoke
The data may be correct for what HONDA intended the guides to do.  ???
"Draw clean air from the air filters".
However in 1967 it was deleted.
The statement Vents On The Head ment that was an easy way to see those heads no longer used the vents.
I've never seen data as to why HONDA discontinued the vents and can only assume they weren't really necessary. .............lm
conbs wrote:LM, I take Bill's quote to refer to the valve guides themselves and not the head casting. Is he wrong?LOUD MOUSE wrote:HONDA discontinued those vents on the head in 1967.
