Steverino's CB77
Post by G-Man » Wed Feb 24, 2016 11:12 am
I posted these in my '61 project thread a while back.....
And this is a weird universal top case I picked up that will work with both early and later oiling systems......
Steverino
Post by Steverino » Thu Feb 25, 2016 11:02 am
Yep, Thanks G, I remember that..................Now. I probably even commented on it when you posted it. Sometimes the old brain just doesn't make the connection. https://www.youtube.com/watch?v=BgqtBm_oUpc
Post by G-Man » Thu Feb 25, 2016 12:13 pm
Steve
I had an experience like that only this week. You suddenly realize that you knew something all along but it just hadn't clicked....
revlover
Post by revlover » Thu Feb 25, 2016 4:53 pm
Great idea, Steve! I could give up my dental plan and buy more bike parts. Going to the dentist is no fun anyway. Classic bikes are always fun and seldom leave your mouth numb.
Steverino
CB77 off the bench and back on terraferma
Post by Steverino » Wed Mar 16, 2016 11:07 pm
I've got the CB77 close enough to being road ready that I took it down from the bench. I want to get it completely warmed up so I can reset the valves and get the carbs just right.. I followed Ed's recipe on tuning. I wish I understood how to set my idle mix screws a little better. Ed says, if I remember correctly, to bottom them then back off one turn but no more than one and a half. I set mine at one and a quarter. I synced the slides, including properly adjusting the cables so the slides lift at exactly the same time. Both pipes warm at the same rate. It will idle at 600 to 800 if it's warmed up. I still need the steering damper and to adjust the brakes. I am sure there will be a lot of little things that will need adjusted over the first couple outings. The motor sounds a lot better in person than my tinny phone can capture. Here is a picture and a video.
ImageIMG_0163 by Steve Steverinomeister, on Flickr
https://www.youtube.com/watch?v=kK_3DNI9AVA
Re: CB77 off the bench and back on terraferma
Post by G-Man » Thu Mar 17, 2016 5:45 am
Great job!
In Brazil currently and there are small bikes everywhere (mainly Brazilian-made Honda 125s). It's just like the old days back home.... :-)
Steverino wrote:I've got the CB77 close enough to being road ready that I took it down from the bench. I want to get it completely warmed up so I can reset the valves and get the carbs just right.. I followed Ed's recipe on tuning. I wish I understood how to set my idle mix screws a little better. Ed says, if I remember correctly, to bottom them then back off one turn but no more than one and a half. I set mine at one and a quarter. I synced the slides, including properly adjusting the cables so the slides lift at exactly the same time. Both pipes warm at the same rate. It will idle at 600 to 800 if it's warmed up. I still need the steering damper and to adjust the brakes. I am sure there will be a lot of little things that will need adjusted over the first couple outings. The motor sounds a lot better in person than my tinny phone can capture. Here is a picture and a video.
Post by Seadog » Thu Mar 17, 2016 8:21 am
Looking good, Steve.
