                    SCREWED BY J.I.S. SCREWS
				3BeanCrispy
I successfully tapped the stator cover holes yesterday. I got a 5mm .8 pitch tap, used oil and air tapping just a bit at a time. However, the hole depth was very shallow and the point of the tap would bottom out before the tap could make it full cut of thread. I got my grinder out and ground off about 3/16 of an inch of the point of the tap, making sure that there was still enough taper to start the tap into the hole. It worked out well and the screws are now in place.
Thanks
Jeff
						Thanks
Jeff
				marzini
I went ahead and installed M5x.8 inserts on the points plate, points cover, rotor cover and the left side starter end cover.  I chose to use hex (allen) type flat-head M5x.8 screws for the points and rotor cover, hex head cap screws for the points plate and button-head screws for the starter cover.
The kit I got from a fastener supply included eight inserts, an insert tool, a drill and a tap. It was $33.
The "hardest" part was installing the inserts for the rotor cover. Those bolt-heads are made of hardened steel. Do all the aluminum J.I.S. threads first and save the rotor cover conversion for last
in case the drill gets dulled or damaged. —Mar'
				PuttinAround
many motorcycle manufacturers used fine or ultra-fine threads in alloy cases for years
they did indeed learn the errors of this practice
coarser threads do indeed work better and last longer in aluminum
the problem with retapping a very fine thread to the same diameter coarse thread is that the minor diameter of the fine thread is larger than the minor diameter (tap drill diameter) of the next coarser thread
this means that retapping a 5x0.8 to 5x0.9 would actually work better for longer thread engagements instead of shorter ones even though the the minor diameter tolerances for shorter thread depths do give the thread tapper a directive to use a smaller tap drill
I haven't dragged out the Machinist Handbook to look at these threads and numbers but my intuition tells me I'd be tapping a 5x0.8 out to a 6mm coarse thread if there is enough metal to do so
especially for very short screws I wanted to actually clamp and stay put
JIS SCREWS
I RECENTLY AQUIRED 12lbs OF JIS SCREWS AND BOLTS. MANY 5MM OVAL HEAD TO FIT POINT AND DYNO COVER. LET ME KNOW WHAT YOU NEED.
				cbxmountainman
CL/CB Screws
I just went and bought the correct ones from Honda. Got the correct sizes from my parts manual. No brainer as far as I'm concerned and a whole lot easier. You'd br surprised what's still available. A little pricey, but worth it to me.
						ISO IS NOT JIS
ALL HONDA PART NUMBERS FOR JIS SCREWS SUPERCEED TO ISO SCREWS. YOU ARE GOING TO BE PISSED WHEN YOU TRY YOUR NEW SCREWS. IF ITS POINT AND DYNO SCREWS YOU NEED? I HAVE SOME NEW JIS 5MM OVAL HEAD SCREWS, LET ME KNOW IF I CAN HELP.
