Rocker arm tool ?
Re: Rocker arm tool
Post by LOUD MOUSE » Thu Dec 25, 2008 12:15 pm
As you will have parts with a large end on 2 you can be sure to install them in the correct location.
The intake ones have the larger end and both can be identified by the size if the oil hole.
Look at the hole of each part and you will see that 2 will have larger holes than the other 2.
The large hole parts are for the intake side and the other 2 are for the exhaust. ..............lm
inog1 wrote:Thanks for all the replies.All were helpfull, and the four pins are now all out without benefit of any special tools.Once again this board has proven its usefulness ! Thanks again all, and HAPPY HOLIDAYS.
RIDE IT DON'T HIDE IT!
inog1
Post by inog1 » Thu Dec 25, 2008 6:51 pm
Thanks mouse for the tip ,I believe I put each assembly in its own ziplock ( I hope ) at least now I can go back and verify if all is as it should be. Thanks again , you are an invaluable tutor
