Snapped Oil filter bolts
young4vr
All snapped, i drilled out
Post by young4vr » Thu Mar 12, 2009 7:32 am
Not having much luck removing the snapped bolts. especially the longer ones. I wanted to remove the pump to check the oil screen and make sure it was clean. Screen was spotless, that is what is making this annoying.
Re: All snapped, i drilled out
Post by LOUD MOUSE » Thu Mar 12, 2009 11:28 am
Odds are that they broke because a previous owner/MECHANIC? installed bolts which were so long they bottomed to the case and were partly sheered when installed and broke apart when ya tried to remove them. I'd say ya need some luck and new stainless thread inserts when ya get the ends out. Good luck. ..................lm
young4vr wrote:Not having much luck removing the snapped bolts. especially the longer ones. I wanted to remove the pump to check the oil screen and make sure it was clean. Screen was spotless, that is what is making this annoying.
RIDE IT DON'T HIDE IT!
Gunner_CAF
Post by Gunner_CAF » Thu Mar 12, 2009 9:10 pm
I had the same problem. A few came out easy with and easy-out, a few didn't. It will leak oil unless you have all 6 in securly. I ended up completely drilling them out and re-taping the holes.
Gunner
