CB77 Timing Chain
48lesco
Post by 48lesco » Thu Apr 22, 2010 1:55 pm
Interesting point, I guess since those "rollers" don't roll, there would only be contact marks and wear from the sprocket on one side. You could turn it inside-out to even it up! Is "pin" chain what I have in the picture? By the way, I've looked at a number of chain sources, and I don't see any 219 chain with actual rollers - its all pin or bushing chain. You sure you got rollers that roll on your cam chains?
Post by LOUD MOUSE » Thu Apr 22, 2010 2:07 pm
Yes I'm sure.
I've been doing engines for others since 1992 and NEVER seen a pin cam chain.
Just ones with a roller over the pin.
Worked on or just disassembled for parts somewhere near 80 engines maybe more and still have apx. 20 others.
The chains I use have a pin with a roller on it and I insist that a new one is installed every time.
Why would you not replace that chain?
A good chain which can have a link cut out and a master link installed usually costs apx $45.00 total. .............lm
48lesco wrote:Interesting point, I guess since those "rollers" don't roll, there would only be contact marks and wear from the sprocket on one side. You could turn it inside-out to even it up! Is "pin" chain what I have in the picture? By the way, I've looked at a number of chain sources, and I don't see any 219 chain with actual rollers - its all pin or bushing chain. You sure you got rollers that roll on your cam chains?
48lesco
Post by 48lesco » Thu Apr 22, 2010 10:02 pm
That's hard to argue with! I guess mine was replaced at one time, and I'll replace it again. PM me with a good source if you can. I appreciate all of your time and experience on this!
