Until you check the engine-running voltages across the battery (you don't need a tacho -- just a perceptive ear), then whether you do or don't have a charging problem cannot be determined. Tending the battery is a shortcut; let's try to get to the root of the problem rather than treat the symptom! Otherwise you run the risk of breaking down on a ride which, in itself, is inconvenient and embarrassing at best and could be more costly in the long run. And running a lead-acid battery to below 80% will shorten its life.Dreamer305 wrote:Thanks for the assistance. I put it on a trickle charge and I'm up and running again. For the time being, I will plan on charging it every couple of weeks until I can find the issue.
Why do half the job?
For the record:
- I ride my CB, sometimes only monthly, for 60% of the year; all short (<10-mile) rides. The rest of the time it's garaged. The battery, still perfect, was two years old when I swapped it out last week for a new AGM. I have never trickle-charged my battery, except one time when testing electrical stuff. CB has:
- A modern, Schottky-diode rectifier
LED stop/taillight
H4 35/35 headlight, always on but the dimmer switch gets 'centred' at a traffic light or when idling
Winkers, 2 x 23W per side, used frequently
A 'Stebel' compact air horn, gets used every bloody ride(!)
I always use the electric starter (my k/s pawl is shagged)
