I always wondered what that little mount was for. I have a CB77 block with one and one without one.
BTW, I have two spare engine cases if you should want one
Do I need to find a replacement upper case?
It's 25.5mm tall, 19mm to center of the tapped hole, and tapers to about 14mm diameter through the tapped hole.
Impurities make welding cast aluminum a little unpredictable, but a MUCH better option than epoxy putty and JB weld.
If you can machine a nice flat surface at the top of your broken boss, you could drill an tap a hole in both the case and a new boss- made from a chunck of aluminum, and use a long set screw as a sort of blind 'stud'.
I sent you a PM, I live fairly nearby and probably have a spare crankcase.
Rick
Rick
