New to forum and need some dream info
Cheburashka
Post by Cheburashka » Tue Apr 19, 2011 9:16 am
Jethro wrote:You don't necessarily HAVE to have the correct battery. The one I put in my '64 is an AGM battery and suits it just fine when it comes to electrical supply and need. It's smaller in size than the original but I just put some foam blocks on the sides to keep it still in the tray. So you do have some options there.
The problem I have isn't size. It's terminal placement. Most of the 12N9-3A batteries I've seen have top-placed terminals. On my Dream, that doesn't work at all. Yuasa used to make a 12N9-3A that had terminals that extended past the battery case on both sides, and that one works too. If you're using a top-terminal version and your '65 is set up like mine, you need to fabricate an extender for the terminal or get a longer ground strap, and you'll need a different battery hold-down mechanism.
Post by LOUD MOUSE » Tue Apr 19, 2011 9:32 am
I have that YUASA 12N9-3A here. ............lm
