Parts compatibility across the years
Post by LOUD MOUSE » Fri Jan 04, 2013 4:56 am
You are correct.
I got the numbers messed up when I tried to make sence of how he posted them. ...........lm
G-Man wrote:I hesitate to question LM, but in my parts book(s)
Part 11200-259-xxx is lower Crankcase
Part 12100-2xx-xxx is Cylinder barrel
For John I believe that the barrels are interchangeable after the early 1961 issue which had a different oil feed arrangement. I have a late NOS die-cast 305 barrel which looks different but appears to be compatible.
Post by davomoto » Fri Jan 04, 2013 7:36 am
The later barrel, while compatible, uses the narrower cam chain tensioner as well.
Davo
Post by G-Man » Fri Jan 04, 2013 8:22 am
Good one, Davo.
I can never remember which way round it is with wide / narrow tensioners.
Post by davomoto » Fri Jan 04, 2013 9:58 am
Yeah G, with all of the nuances throughout the years, it's hard to keep track of what was early vs late(r).
Davo
John Kat
Post by John Kat » Fri Jan 04, 2013 10:49 am
The obvious next question is can you recognize the one from the other?
For instance would this one fit a late model 1965?
http://www.ebay.com/itm/251097130500?ss ... 1423.l2648
Post by davomoto » Fri Jan 04, 2013 2:29 pm
John,
Measure the height and width of the cam chain tensioner on your motor, and have the seller measure the barrel. The changes occur more by serial number than model year. Also could have been swapped before, so definately measure!
Davo
Post by LOUD MOUSE » Fri Jan 04, 2013 4:16 pm
If your engine is a 1965 the part will fit/work. ....lm
John Kat wrote:The obvious next question is can you recognize the one from the other?
