Removing the rear shock on a CB77
JSharpPhoto
Post by JSharpPhoto » Thu Aug 08, 2013 11:08 pm
Thanks for the tip. I'll make sure to address that when I install the hagons.
cknight
Post by cknight » Fri Aug 09, 2013 8:06 am
The clevis on the Hagon shocks is thicker than the stockers, so the bolt will not have enough threads exposed to properly tighten the nut. You'll be better off installing the Hagons with the threaded side of the clevis inward, then install the bolt (with a lockwasher under the head) from the outside. There will be about one thread of the bolt exposed inboard, and that will not interfere with the chain. (OCD Purist disclaimer in effect) Regards, Chase
JSharpPhoto
Post by JSharpPhoto » Fri Aug 09, 2013 9:57 am
cknight wrote:The clevis on the Hagon shocks is thicker than the stockers, so the bolt will not have enough threads exposed to properly tighten the nut. You'll be better off installing the Hagons with the threaded side of the clevis inward, then install the bolt (with a lockwasher under the head) from the outside. There will be about one thread of the bolt exposed inboard, and that will not interfere with the chain. (OCD Purist disclaimer in effect) Regards, Chase
That's exactly what I had in mind. Thanks for confirming.
