My Dream Begins (Restoration Project)
Hahnda
Post by Hahnda » Mon Oct 21, 2013 8:07 pm
Heat gun on the carb slide, it will soften the gas that has turned to glue. You may just want to cut the cable so you can at least get it out into a area where you can work on it easier.
Tango911
Post by Tango911 » Mon Oct 21, 2013 8:29 pm
wow, thats taking on a project!! good luck!! cant wait to see it.
65 Sears Puch 250
69 Dream 305
74 Kawi H1
78 CB750 SS
Bradha562
Post by Bradha562 » Mon Oct 21, 2013 8:46 pm
Hahnda wrote:Heat gun on the carb slide, it will soften the gas that has turned to glue. You may just want to cut the cable so you can at least get it out into a area where you can work on it easier.
Thanks I'll give the heat gun a try. I'm hoping to use as many existing parts as possible in order to keep costs down but if the heat gun doesn't work I'll cut the cable. Ugh!
Bradha562
Post by Bradha562 » Mon Oct 21, 2013 8:47 pm
Tango911 wrote:wow, thats taking on a project!! good luck!! cant wait to see it.
Thanks! I hope I'm not in too far over my head...
brewsky
Post by brewsky » Mon Oct 21, 2013 9:04 pm
you should be able to unhook the cable at the grip end and snake it out of the frame
on the dipstick, some heat, pb blaster and a crescent wrench should do it
patience is the key...it will be a learning experience for sure!
on the solenoid, put 12volts across the 2 small wires....that should cause continuity between larger terminals when you do
Bradha562
Success!
Post by Bradha562 » Mon Oct 21, 2013 11:49 pm
But...
Time for a bath...
brewsky
Post by brewsky » Tue Oct 22, 2013 3:57 am
That'll work too.....
Looks like you're on a roll!
