CB77 petrol tap
SMBH
Post by SMBH » Sun Dec 22, 2013 2:34 pm
I have recived the new petrol tap (petcock) it is smaller than the old tap the 2 feed take offs are on the left hand side of the tap were as the old one had the take off on the right hand side, I now find that the new tap out let pipes are touching the carb top I can only use the new tap with it tuned on it's sidewith the lever facing towards the rear of the bike.
The position of the outlet on the petrol tank needs to be further back towards the seat or closer to the edge of the tank.
The old larger tap I took off was a tight fit and was touching the air tube to the carb.
So did Honda make diffrent tanks for the CB77 my bike is 1964 im not saying it is the correct tank it looks ok ?
Is there a way round this problem, I was thinking of filing a little off the side of the new tap on the left hand side by the two outlet pipes so I can rotate the tap so as the lever is faceing towards me and not have it face the rear of the bike.
Any one encounted this problem with the later (see the first posting for the link to the petcock I purchased ) petcock.
And a very merry Christmas to all and a safe riding new year.
Post by LOUD MOUSE » Sun Dec 22, 2013 3:12 pm
That valve isn't near correct.
They sell a couple of items which look close but are not correct for the bikes they list them for. .........lm
SMBH wrote:I have recived the new petrol tap (petcock) it is smaller than the old tap the 2 feed take offs are on the left hand side of the tap were as the old one had the take off on the right hand side, I now find that the new tap out let pipes are touching the carb top I can only use the new tap with it tuned on it's sidewith the lever facing towards the rear of the bike.
SMBH
Post by SMBH » Sun Dec 22, 2013 3:29 pm
Thanks LOUD MOUSE for the fast reply, so back to the drawing board im looking for another original tap (valve) or just the main body the thread has gone and colapsed on the one I have.
I may just give the JB weld a go to repaire it if I can not get a replacment.
So has any one got a petcock, valve, petrol tap what ever you wish to call it for a 1964 CB77 they wish to sell I live in the UK.
Thanks.
jambretta
Post by jambretta » Sun Dec 22, 2013 11:55 pm
You likely have a CL77 petcock. The CL tanks had the petcock mounted on the right side of the tank, so the two spigots for the lines to the carb were to the left (when facing the petcock valve lever). Probably mislabeled by seller.
Pelayo
Oakland, CA usa
Post by LOUD MOUSE » Mon Dec 23, 2013 6:56 am
He shows the valve he bought from "siriusconincnosparts" that looks good until you try to instal it in the first question he asked.
Take a look. ............lm
jambretta wrote:You likely have a CL77 petcock. The CL tanks had the petcock mounted on the right side of the tank, so the two spigots for the lines to the carb were to the left (when facing the petcock valve lever). Probably mislabeled by seller.
Pelayo
Oakland, CA usa
SMBH
Post by SMBH » Mon Dec 23, 2013 11:12 am
Yes it was listed as to fit for the later CB's, it looks well made and the right price for me.
I intend to file the side to see if I can turn it so the lever faces the side after all if the orignal is not avalable then one has to compromise.
SMBH
Post by SMBH » Tue Dec 31, 2013 3:55 pm
Still looking for a petrol tank tap for my 1964 CB77, I have found other taps of other bikes but I wish to know the petrol tank outlet thread size it is 16mm x ? what is the pitched thread size any one know.
