gas tank install
twoleggedsnake
the frame # is ca78 1032148 the tank is original to the bike as far as i know...front of tank hits handlebar collar just before petcock nipple clears the front edge of metal support...tank at that point is about half way engaged on the rubber cushions in front... its so close but dont want to booger anything up trying to force...thanks again for everyones help
twoleggedsnake
2LS - Don't be anxious about those washers, just make sure the underside of the screw heads and the mating surfaces on the petcock are clean and not too pitted. You can use a little valve grinding compound there to spin in a smooth surface if you need to. I usually install the petcock without the bowl and put a little gas in the tank to see if they are gas-tight and they usually aren't so you have to tighten them a little more. If you use the OEM Honda fiber ones, I think they swell a little with time and seal up eventually. I've never tried the aluminum crush washers from the ebay aftermarket kit, but would like to know how well they work.
-48
-48
- hondadreamca77
Late reply
I had no problem with the aluminum crush washers. I did coat the end of the screw that goes up into the tank with perm a gasket as well.
My 68' Dream has the same petcock / mount tab problem....have to jiggle it just right to get onto the bike and slide forward. I've thought of slightly grinding back the front section of the tab (where it hits) a bit to give some clearance.
Steve
Steve
68' 305 Dream, 75' Honda 750-four, 74' Honda CL 125, 72' Honda CA 70, 80' Honda Passport, 74' Aerimachi Harley Sprint 125, 64' Yamaha 90.
