G-Man wrote:I use a tool made from some fittings an a High Tensile M6 bolt.
Rocker pin puller 2 by graham.curtis, on Flickr
You could make up something similar with a large socket and some washers.
rocker pin puller by graham.curtis, on Flickr
The rocker shafts are threaded to take a special Honda tool but mine works pretty well.
rebuild
A center punch on the other end when hit with a hammer will knock that shaft out enough for you to remove it easily. ..............lm
