Paint job ?
mike1969
paint
Post by mike1969 » Mon Oct 06, 2014 2:30 pm
Used Duplicolor GM- Bright red on my Dream. It's a pretty good match to original. The spray nozzle on Duplicolor paint does an amazing job.
You have to supply the color sanding and rubbing compound to bring out a nice shine.
JonnyT
paint
Post by JonnyT » Mon Oct 06, 2014 2:38 pm
Got it and will do; thanks. Which paint remover did you use?
mike1969
paint job
Post by mike1969 » Mon Oct 06, 2014 2:47 pm
I used aircraft paint remover I got at parts store. Either Advance auto part or Autozone, don't remember. Brush it on and use a putty knife to scrape off. Works really well but you will still have to finish it off with sandpaper.
My bike had 3 coats of paint.
lrutt
Post by lrutt » Thu Oct 09, 2014 7:23 am
While you might be able to make it look half way decent, it will never be very gas tolerant / resistant. That is the biggest draw back to rattle can on gas tanks that I've seen. Nothing beats a 2 part for making a good tank finish that will survive the occasional splash. Plus I've never been able to get a rattle can job have as good of gloss finish as a regular automotive 2 part.
and for reference, the only kind of paint I use is acrylic enamel with hardener, it's tough, easy to apply, single stage, and cheap.
mike1969
paint
Post by mike1969 » Thu Oct 09, 2014 7:50 am
Depends on how much money you want to spend, whether you want a rider or a show bike and your painting abilities.
I got a very nice paint job with Duplicolor. The last Dream I painted did have the gas drip on the tank problem, but my present bike doesn't seem to have a problem with gas. Maybe they changed formula?
Something that might be worth looking into would be the 3M clear plastic coating I've seen advertised on tv. It makes a spray on plastic covering that can be removed. Anyone tried this?
hotrodhendrix
Post by hotrodhendrix » Thu Oct 09, 2014 3:42 pm
90% of mine I powdercoated and the other 10% is cadmium coated or Alumablast by Eastwood automotive type.
Honestly for the cost of spray cans you can get a harbor freight gun, borrow an aircompressor and get some decent paint. Will look better and last longer. Just my 2 cents.
~James
Post by G-Man » Thu Oct 09, 2014 3:50 pm
This is my Dream C72 painted 'al fresco' with small compressor and HVLP spray gun. The guns are so cheap that I have different ones for primer, topcoat and clear coat.
So much nicer to use than spray cans.
C72 Parts - painted
by graham.curtis, on Flickr
