Super Slow 65 CB77 Restoration commences
Post by G-Man » Wed Nov 19, 2014 2:21 pm
They have a place in the US now.
https://www.davidsilverspares.com
Just put a box under the engine. Undo the bolts and lift the frame off.
jugger18 wrote:Thanks everyone. I am following David Silver Spares on Facebook and did see that. I wonder how bad shipping to the US will be. For that much I will let someone else be the Guinea Pig :) This weekend I plan on dropping the engine and taking it down to the basement shop. How heavy are the engines dry?
jugger18
Post by jugger18 » Wed Nov 19, 2014 2:33 pm
That is how I have it now. It is sitting on a milk crate :) I will have to transport it from the garage, into the house and down to the basement though. I am a fairly strong guy, just wondering if I should enlist help for the moving portion
Post by G-Man » Wed Nov 19, 2014 3:05 pm
I have carried them on my own but I don't think I'd want to carry one any distance and definitely not down a flight of stairs. If you can get help, go for it.
Hahnda
Post by Hahnda » Wed Nov 19, 2014 5:58 pm
Remove whatever parts you can to reduce weight. Every little bit will help.
jugger18
Post by jugger18 » Wed Nov 19, 2014 6:07 pm
Any hints on the rear brake cable removal from the hub
sarals
Post by sarals » Thu Nov 20, 2014 9:54 am
jugger18 wrote:Any hints on the rear brake cable removal from the hub
I don't recall it being an issue. Loosen the adjuster locknut and turn the adjuster enough to free the cable from the brake arm on the hub, and then unscrew the cable from the flange on the brake backing plate. Is yours stuck?
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
jugger18
Post by jugger18 » Thu Nov 20, 2014 11:13 am
I will have to look when I get home but I dont recall seeing a locknut like I had on the front cable
