CB77 jumps into gear when pushing
will305
Post by will305 » Sat May 30, 2015 6:20 pm
bamacl wrote:The kick starter return spring keeps tension on the shaft to disengage the starter pawl in the normal position. If the kick starter is missing then the pawl might not be disengaged.
Would that cause it to jump into gear?
Thanks,
Will
will305
Post by will305 » Sat May 30, 2015 9:00 pm
Here is may attempt at some pics.
Will
will305
Post by will305 » Sat May 30, 2015 9:01 pm
Will
Wrong picture…sorry!!
Post by LOUD MOUSE » Sat May 30, 2015 10:36 pm
I've had the kick shaft rotate and lock up the trans when the lever isn't installed.
It's different when the engine is running than just turning the rear wheel.
You are welcome to visit.
Please do. ..............lm
will305 wrote:
LOUD MOUSE wrote:Do you have the kick starter lever installed correctly?
Does it move as you roll the bike?. ..............lm
LM,
Actually, the guy hasn't sent me the kickstart lever yet, so it's not installed. In watching closely, the lever shaft doesn't appear to move as I spin the wheel on the stand.
I know that with the limited info I'm able to provide, this is really tough for you guys to diagnose. Was hoping it might be a common symptom you've seen before. I am going to proceed with all the other steps I need to do in order to get it running (oil, carbs, new battery, etc), and then see if this is still an issue.
LM, I see you're in Kerrville….maybe I will have a chance to meet you if you attend the Harvest Classic in Luchenbach in October…I plan to go this year.
Thanks for the help on this.
Will
