1965 CA77 DREAM 305 should they only have 1 carburetor
deafanddiabetic
Post by deafanddiabetic » Tue Sep 15, 2015 9:24 am
I've owned way too many bikes from the 50's to 80's and I don't think I've ever had a bike that the throttle would return on it's own. They've all required at least a little twist to get it to come back, but all of them were buttery smooth.
I replied in your other thread roadrunner, but I would start with your timing adjustment and valve clearances before tickling with the carburetor. Always the last line of defense.
1964 CA72
1974 BMW R75/6
1969 CL450
roadrunner
ca77 dream305
Post by roadrunner » Tue Sep 15, 2015 10:10 am
thanks for the info.good advice i guess you go step by step.
mike1969
Re: dream ca77
Post by mike1969 » Tue Sep 15, 2015 5:48 pm
[quote="roadrunner"]i hadn't realized,do you know anything about throttle's i took my grip off and cleaned the tube and the throttle still wont spring back. the cable doesn't have any way to adjust it there.thanks so much for your help this is my first restro.[/quote]
There is a throttle return adjustment on the underside of the starter button mount. It's a set screw with a lock nut. Mine is completely gone and I get a decent recoil on the throttle.
roadrunner
ca77 dream305
Post by roadrunner » Tue Sep 15, 2015 6:15 pm
i see where the screw was & i don't have the starter button either.you don't happen to know how to time the bike without a timing lite,i cleaned the plugs & set the points but i don'y have a timing lite.did you go pointless?
Hahnda
Post by Hahnda » Tue Sep 15, 2015 7:25 pm
Do you have a voltmeter or just something as simple as a 12v bulb and wire? You can static time it fairly easily.
roadrunner
ca77 dream305
Post by roadrunner » Tue Sep 15, 2015 7:39 pm
yes i can get my hands on a 12volt bulb & wire the trick is what do i do?this is like McGyver stuff.
Eljeef
Post by Eljeef » Tue Sep 15, 2015 7:55 pm
I believe Paperslammer wrote an excellent tutorial on how to set the timing on the Dream. Check it out.
1964-C77 305 Dream
2002 BMW R1150GS
