As the parts are in line as you show them you will find the tube is machined so only the correct ring will install at that point.
The seal has a steel outer winch in all the years I've remove them I've used a chisel which is 1/8
wide and colapse that steel outer into the center.
Rather difficlt to describee so I hope others can offer the way they remove th seal. ..............lm
Husker45 wrote:After finishing my chores I went back to work on the fork. I got the knock pins out and disassembled it. However I am confused. On the pipe fork there are two grooves for snap rings. On my fork there was no snap ring in the lower groove, one snap ring in the upper groove, and a snap ring just floating on the pipe fork above the upper groove (but below the fork pipe guide). In the parts manual it shows a fork pipe stopper ring, fork piston snap ring, and a fork valve stopper ring. Which is which and where do they all go.
The photos below show the parts I have and the order they were removed from bottom to top of the fork. The photo doesn't show the oil seal because I can't for the life of me get it out of fork seal housing.
As always thanks for the help.
Husker
