Thanks for that tip; it sure looks good on that engine. Does it require a primer? Is your wife still talking to you? :-)48lesco wrote:VHT High Temperature Engine Enamel SP127 Universal Aluminum is a good match in my opinion. I use it on all of the painted parts of the engine (clutch, kicker, valley, and starter covers, as well as the starter). I like it because you can bake it on for 20 minutes and then it has excellent fuel resistance. Instructions on the can. I used the kitchen oven and it doesn't leave any odor. I did not ask for permission to do that beforehand...
                    Super Hawk Engine Cover Color
As stated before I use KRYLON DULL ALUMINUM and no bake but easy to do a simple touch when your shoe/boot wares through on the clutch cover. ...........lm
Easy touch up is an important consideration, LM. As someone once said, sh*t happens. I've been using "Cast Coat Aluminum" Duplicolor high temp engine paint so far, but I've never tried a touch up. I think I'll give that a try on something to see if it works out as well as your Krylon has.LOUD MOUSE wrote:As stated before I use KRYLON DULL ALUMINUM and no bake but easy to do a simple touch when your shoe/boot wares through on the clutch cover. ...........lm
Let us knw how it works out. .............lm
						Seadog wrote:Easy touch up is an important consideration, LM. As someone once said, sh*t happens. I've been using "Cast Coat Aluminum" Duplicolor high temp engine paint so far, but I've never tried a touch up. I think I'll give that a try on something to see if it works out as well as your Krylon has.LOUD MOUSE wrote:As stated before I use KRYLON DULL ALUMINUM and no bake but easy to do a simple touch when your shoe/boot wares through on the clutch cover. ...........lm
I tried the Krylon and it also matches well, but I wanted something a little tougher and fuel resistant. I don't use primer on the aluminum parts, but I did on that particular valley cover because it was pitted like yours. I recall three or four coats with sanding in between to get it smooth. Another tip is to put the rattle can in hot water for a few minutes before shooting to reduce orange peel. And no issues with using the oven, not sure I ever mentioned it...
						Thanks for that hot water tip, 48lesco.  I wasn't able to paint yet as I was getting a horn body ready to paint at the same time.  I should be getting to it tomorrow.  I'll also be spraying multiple prime coats, sanding between.  Yours came out great.
						48lesco wrote:I tried the Krylon and it also matches well, but I wanted something a little tougher and fuel resistant. I don't use primer on the aluminum parts, but I did on that particular valley cover because it was pitted like yours. I recall three or four coats with sanding in between to get it smooth. Another tip is to put the rattle can in hot water for a few minutes before shooting to reduce orange peel. And no issues with using the oven, not sure I ever mentioned it...
I paint during the day and place the can in the sun as I do other thongs then leave the can in the sun before the next coat. ..............lm
						Seadog wrote:Thanks for that hot water tip, 48lesco. I wasn't able to paint yet as I was getting a horn body ready to paint at the same time. I should be getting to it tomorrow. I'll also be spraying multiple prime coats, sanding between. Yours came out great.
