starter sprag-clutch
Post by Seadog » Sat Jul 28, 2018 3:06 pm
I couldn’t budge the plugs with a punch, so i left the alone. I drilled the spring caps with a 1/8” drill bit. They spun and caught on the bit and I was able to pull them out with the bit.
modelman wrote:Its the same as mine, they would have punched straight through!!
Also, since you drilled them out, whats keeping the springs in place, do they go into the drilled hole??
