Newbie update & need help - No Spark
pknopp
Re: no points
Post by pknopp » Thu Jun 30, 2011 1:54 pm
kenkah wrote:Turns out that There were no points under the cover. I did find what looks to be another part but I have to see if it matches up
LOL, well that would most likely be your problem...
Luckily points are cheap.
kenkah
Re: no points
Post by kenkah » Thu Jun 30, 2011 7:10 pm
Yeah already ordered it.
How to go about checkin the condensor?
I know that the wire to the points is working, Found out by accident but there is power there.
kenkah
Got spark
Post by kenkah » Fri Jul 08, 2011 8:00 pm
well I got spark now I have a fuel issue, I have drain hose on the bottom of the carb and it is basically draining all the fuel. I read on a few older posts that this isnt needed. do most of you plug the tube?
Post by G-Man » Sat Jul 09, 2011 3:21 am
The float and float valve should cut off the fuel when it reaches the right level in the carb. You need to dismantle the carb and see that the float is free to move and that the float valve is sealing properly.
