Clutch issues
Re: Clutch issues
Post by LOUD MOUSE » Tue Feb 14, 2012 8:09 am
Not really as yours is installed correctly. .........lm
rzgkane wrote:
LOUD MOUSE wrote:Readjust the cable ends to bottom then loosen the bolt with the 10mm head near Large Adjuster in the case.
Turn the adjuster to the right to stop then back apx. 1/8 inch and tighten that bolt.
Use cable adjusters to fine tune. ......lm
I performed this on my 1965 CA77. Before it, the adjusters at both the lever and clutch case cable entry point were waaaay out as if they were taking up a lot of slack. After, they are much more in the range of what I think is normal. The question I have is whether the adjuster disc (large slotted piece that you turn right and back off 1/8") is supposed to be pointing in any particular direction or place after adjustment?
Before adjustment:
IMG_0508 by rzgkane, on Flickr
After adjustment:
IMG_0562 by rzgkane, on Flickr
Position of adjuster after adjustment:
IMG_0563 by rzgkane, on Flickr
