exhaust studs
cdf7640
Post by cdf7640 » Wed Aug 31, 2011 4:34 pm
Just measured the stud and it's 40mm long. The part that's exposed outside of the cyclinder head is around 28 though - you're right.
I found some replacement studs on this VW parts site:
http://www.wolfgangint.com/Parts/Studs/Type+2/
Never used a Helicoil - does it just lock the threads in tighter and ensure that it doesn't seize?
Thanks for the help!
Chris
Hahnda
Post by Hahnda » Wed Aug 31, 2011 4:45 pm
I just measured also and it is 40. Not sure where I'm getting 28.
Anyway the one you link to should work fine.
cdf7640
Post by cdf7640 » Thu Sep 01, 2011 1:11 pm
Perfect. I keep reading differing opinions on whether anti-seize, loctite, or nothing at all should be used when installing the new studs. What's your opinion?
Thanks for your help!
C
Post by LOUD MOUSE » Thu Sep 01, 2011 7:23 pm
I use Nothing. ........lm
cdf7640 wrote:Perfect. I keep reading differing opinions on whether anti-seize, loctite, or nothing at all should be used when installing the new studs. What's your opinion?
C
cdf7640
Post by cdf7640 » Thu Sep 01, 2011 10:36 pm
Good to know. Thanks lm
