I'm Rich!
leonvjames
Post by leonvjames » Sat Jun 24, 2006 4:01 am
When my bike (CB77) was new I had several cases of cracked pistons in the first 30.000 miles. I put this down to too smaller main jet. Mixture was just a wee bit lean on the standard 120 jets so going to 130 should help to eliminate this problem. I went to a 350 kit and all the changes that involved. Now done 135.000 miles and had other hassles but no more cracked pistons.
Leon.
mustanger
Post by mustanger » Sat Jun 24, 2006 9:08 am
Sounds like you had the opposite problem than this one. However, it's still interesting. I know that leaner mixtures cause the motors to run hotter, but so hot you cracked the pistons??? Didn't you hear the hear the engine knocking before this happened?
leonvjames
Post by leonvjames » Sun Jun 25, 2006 12:14 am
no, the motor tightened then just seized. I used to pull in the clutch and coast for a while then drop the clutch and proceed a bit slower followed by clouds of blue oil smoke. Used to use a fair bit of oil then so I resorted to running the breather into a plastic bag or bottle to catch the oil blown out and then every so often just tip the oil collected back into the sump. I managed to get home most times like this. Interesting times.
Leon.
