cl 77 clutch stuck
Post by LOUD MOUSE » Sat Sep 08, 2012 6:29 pm
Well maybe.
Thank you.
Good to hear you have it going. ...... ...........lm
milwaukeephil wrote:
LOUD MOUSE wrote:Did you adjust the LARGE adjuster held tight with that bolt with the 10mm head?. ......................lm
milwaukeephil wrote:I'm having a similar issue on my '66 CA77.
Clutch cable broke while riding. I replaced the cable and the new cable doesn't disengage the clutch. I tool off the oil slinger cover and watched the clutch basket jiggle a tiny bit when I pull the clutch lever.
I have the cable as tight as possible. Everything feels right, but the clutch doesn't disengage (up on center stand, trying to turn the back wheel by hand with clutch lever pulled in). Any ideas?
My push rod can be pushed in easily by hand about an 1/8" and then it hits what feels like a solid metal wall. I know it should be tight, but it just doesn't feel like its pushing the rod in.
Any thoughts?
That was it. You're good, Mr. Mouse.
milwaukeephil
Post by milwaukeephil » Sat Sep 08, 2012 6:32 pm
Do you have any magical tricks like that to make it run with the headlight on. Runs fine until I turn the key to the notch for the headlights. Battery is not healthy; could it be that simple?
Post by LOUD MOUSE » Thu Sep 13, 2012 9:51 pm
Usually for these engines to run well the battery should have at least 12volts and if you turn the lights on and it quits it may be the battery.
See if you can rev it up then turn the lights and see what happens. .....lm
milwaukeephil wrote:Do you have any magical tricks like that to make it run with the headlight on. Runs fine until I turn the key to the notch for the headlights. Battery is not healthy; could it be that simple?
