oil leak
Re: oil leak
It will cause the oil to puddle between the top cover and gaskets and the oil will come out the tube.
Usually when you run above idle. ...........lm
Dan Atsma wrote:maybe the former owner did, would that slowy get worse? it happened a couple of time after hard use and now its steady. thanks for your help!LOUD MOUSE wrote:More often than not we find the gaskets under the top cover have the small holes which are supposed to be in the front have been put to the rear. .............lm
Dan Atsma wrote:confirmed the oil is coming out of the top vent tube, I have not had the top cover off. It seems to be leaking around the cover also.LOUD MOUSE wrote:Yes.
Have you taken the top cover off the engine?. .........lm
Dan Atsma wrote:If I'm looking at it correctly, that's where I was thinking the oil was coming from, that dumps into the side cover through a rubber line. Am I looking at that correctly?LOUD MOUSE wrote:Check the top vent tube and make sure it is open. ..........lm
Dan Atsma wrote:Any thoughts? Scrambler is leaking oil out the right side of the case, a lot of oil. The oil level is correct (it was down), took the side cover off cleaned everything up and rode it 1/2 mile no leak, ran it two miles at 55 and it spewed again. is there a vent that could be plugged and causing it to overheat?
I'm confused!
Dan Atsma
- Contact:
Re: oil leak
Thanks, I will check that and adjust the tappets and see if that clears it up
LOUD MOUSE wrote:It will cause the oil to puddle between the rop cover and gaskets and the oil will come out the tube.
I'm confused!
Toad
65 CL77 305 Scrambler, 75 CB750K Cafe, 75 CB750F
Do I have the same problem? Lost power and stalled after running about 20 minutes at pretty high RPM's. I noticed oil leaking from the right side cover so i trailered it home. When I removed the right side cover this is what I found. The bike has been in my family since new and has about 27k miles on it without any motor work ever being done. Hopefully I can get it up and running again.
Thanks,
Brian
Thanks,
Brian
What is the problem you think you have in the pic?. ...........lm
big-b wrote:Do I have the same problem? Lost power and stalled after running about 20 minutes at pretty high RPM's. I noticed oil leaking from the right side cover so i trailered it home. When I removed the right side cover this is what I found. The bike has been in my family since new and has about 27k miles on it without any motor work ever being done. Hopefully I can get it up and running again.
Thanks,
Brian
