After watching your video and what you called "play" in the advance unit I went out to my spare motor (albeit a CA77 motor) and tested it. I also had roughly the same amount (or degrees) of movement before I felt tension in the springs, but I had the benefit of being able to watch the advance weights while moving the points shaft because the top of my spare motor is off. What I saw was immediate movement of the advance weights upon any slight movement of the points shaft. Were you feeling like you were advancing too soon because of what you believed to be slop in the mechanism? Because the springs were not acting early enough as a deterrent to the engines natural desire to want to sling those weights outward? And now, because the springs are too tight, you need more RPM than is correct for the engine timing to advance?
Jlovvorn wrote:Well, at least someone can learn from me.
I overdid the springs, and it doesnt advance until 5000.
Hits 5000 and take off like crazy.
