Compression imbalance? Or one plug sparking better under compression? How's the mixture for each side? Try swapping the plugs over.If anybody cares to comment about my earlier question concerning the imbalance of exhaust pulse between the two mufflers, don't hold back!
Fresh meat!
Re: ride report
FOR IMBALANCE OF EXHAUST PLUSE PLEASE CALL ME. ..............lm
Loudo wrote:Went for a 9 mile ride at lunch, about a half hour of riding. Took it up to 50 on the state route, all the gears seem fine. After the ride, there were a few drops of oil here and there. Of more concern, the centerstand was coated with oil and there were signs of oil being lightly sprayed onto the right side of the rear wheel hub. I'm wondering if the chain is throwing this oil around or if it is leaking from somewhere and the wind at speed is driving it onto these other surfaces.
I don't know what I'd do with myself if I didn't have a new problem to troubleshoot.
RIDE IT DON'T HIDE IT!
Re: Uh oh
OK. JUST WANTED TO EXPLAIN HOW TO GET THEM TOGETHER. GOOD TO KNOW YA GOT THEM CORRECT. ...............lm
Loudo wrote:Oh no...now I've been called into the principal's office.
"Uh, my exhaust pulse is fine, Mr. Moore...honest!"
Re: Uh oh
How about a quick explanation LM! I had this same issue before I tore my superhawk back down for paint. Figured I would sort it out later - sure would be nice to know what to look out for!LOUD MOUSE wrote:OK. JUST WANTED TO EXPLAIN HOW TO GET THEM TOGETHER. GOOD TO KNOW YA GOT THEM CORRECT. ...............lm
Thanks,
Byrd
Re: Uh oh
It's usually one carb slide is lower than the other and ya need to tuen the colder one in a half turn at a atime and as the engine speeds up turn the other out a half turn until the engine is running smooth. ............lm
byrdman76 wrote:How about a quick explanation LM! I had this same issue before I tore my superhawk back down for paint. Figured I would sort it out later - sure would be nice to know what to look out for!LOUD MOUSE wrote:OK. JUST WANTED TO EXPLAIN HOW TO GET THEM TOGETHER. GOOD TO KNOW YA GOT THEM CORRECT. ...............lm
Thanks,
Byrd
Re: Uh oh
LOUD MOUSE wrote:It's usually one carb slide is lower than the other and ya need to tuen the colder one in a half turn at a atime and as the engine speeds up turn the other out a half turn until the engine is running smooth. ............lm
Got it. I'll keep this in mind when I get it all back together - thanks.
Now back to Loudo!
Thanks,
Byrd
