Steverino's CB77
Inner Swingarm Bronze Bushing/Frame Clearance Problem
Hi Everyone
I am using DSS bronze bushings on my swing arm. The part of the bush that is exposed after they are installed is quite a bit thicker than the originals. My frame is powder coated so I knew I was going to have to file that off. But I don't think that is going to be nearly enough. Do you suggest filing the bushes back until they clear? I'd rather ask a dumb question than fix a stupid mistake.
Thanks
Steve
Thanks
Steve
Steve
I would adjust the flange on the bushes until they are the same as the originals. Strange that they would make them thicker...
I have the luxury of a lathe so easy for me. Careful filing with constant checks that you have the flange level should work. It would also be worth telling DSS that they are not right.
Have you pressed them in now?
