How to set points gap/arcing
Terry McKitrick
Post by Terry McKitrick » Tue Sep 12, 2006 10:26 am
The 1966 Superhawk I am restoring has a lot of arching going on around the points, which appear to be set at about .011. The spark plugs are new, and I have not checked their gap. I have new points that I have not installed because the shop manual (page 7) is confusing, to say the least (it says 0.3 - 0.4, .0118 - .0157). These settings don't seem to make sense.
What should the setting really be?
It appears that the points gap is at it's maximum when the line on the rotor is pointing at right angles away from the contact. Correct?
I replaced the screw eye connectors to the points, and they may be slightly larger than the original. Could this be causing the arching?
Help! The snow is coming.
Terry McKitrick
CP1000077, CP77E1000074
St. Albert, Alberta Canada
piecutter
Post by piecutter » Tue Sep 12, 2006 10:42 am
Click on "FAQ" on the left hand menu bar.
Select "How do I tune my factory stock motor on my CB72/77 or CL72/77 for optimum performance?".
Follow Ed's instructions to the letter! Read it once or twice before you start!
Post by LOUD MOUSE » Tue Sep 12, 2006 5:46 pm
Thank you for the referral. I always like to know that others use my sugestions for their bikes. ..........lm
ote="piecutter"]Click on "FAQ" on the left hand menu bar.
Follow Ed's instructions to the letter! Read it once or twice before you start![/quote]
piecutter
Post by piecutter » Wed Sep 13, 2006 2:34 am
Hey, saves me a lot of typing!
