4shorts wrote:LOUD MOUSE they were on wrong and I changed them over and also updated the pictures. Sorry for the
confusion. Paul
The rebirth of a C78 305 Honda Dream
UPDATED! NOV.17/2006
Well I finally got some extra time to reassemble the rear shocks. I had purchased two used ones off of Ebay because the inner shocks on my bike were leaking. After receiving the Ebay shocks and removing the outer components I was pleased to know they were in perfect condition. As I did with the rest of my aluminum parts of this bike I used etching primer and base coat clear coat to refinish them.
I had the lower parts of the shocks replated so all I had to do was reassemble them. I thought I would have to make a small spring compressor to put them back but after a little thought I found a simple way to do it. Here's how I did it:
- Place a piece of round stock through the lower bushing of the lower shock and clamp it in a vice.
- Lay the lower chrome section on the shock.
- Lay spring over the shock and apply some grease in the upper plastic part of the spring.
- Make sure the threads are clean in the small collar and while pulling down slightly on the spring have an assistant spin the collar on the thread of the shock. It only needs to go on enough to be able to hold the threaded part with pliers and use a 17 MM wrench to tighten it all the way down on the shaft.
- Now lay the plastic portion of the shock over the shaft and while you use both hands to pull this section down over the small collar have your assistant spin the very top portion of the shock on. Then he will take the 17 MM wrench and tighten the collar up tight against the top portion of the shock. When this is done let to plastic portion of the shock go up and meet the upper part of the shock and the job is complete.
I tried to take as many pictures as I could but a third person would have been beneficial in this case but I hope it helps some of you out. Clear as mud isn't it?
Thanks FiremanBob for that. Heck I'm just happy to know someone is actually reading the posts! Not much discussion on here for a discussion forum and there are times I wonder why I bother to post anything at all. I'm used to some of the GoldWing forums I guess. There always something to talk about over there.FiremanBob wrote:Thank you for posting that excellent tutorial.
That being said I decided to assemble the front fork section of the Dream today while trying to learn how to use a new camera. Got most of the camera figured out if I could only figure out how to add the date to the pictures.
I assembled the petcock today and finially received my fuel bowl. I'm not going to give Mr. Honda any pats on the back for the petcock design on these bikes because I think it comes with a few flaws. I also got the front end together easy enough. I'm not looking for a points bike so everything won't be original and that don't worry me in the least as long as the beast is reliable, well done and don't fall apart when I go down the road I'll be happy enough. I'm still waiting on my outer chrome rims and my tires. After they arrive It won't be long and I'll start to make some real progress.
Come on everyone. Wake up and start posting on this site. I'm falling asleep!
