G'Day All
One of the many things I have never been able to find is the correct setting for the clutch springs tension.
Is it like some others where you screw down the spring bolts a predetermined number of turns or are the bolts just screwed home?
What brings me to the question is that the effort to pull the clutch lever seems more than other similar bikes.
Mine has always been thus with old or new cables and lubrication, it all functions well apart from this.
I suppose what I want to find out is the adjustment setting and is the 'strong' hand of it the norm for the CB77?
Cheers! .......... Blakey
Clutch spring tension setting
Re: Clutch spring tension setting
Tighten the 4 bolts to a good tight feeling. ...........lm
Cheers! .......... Blakey[/quote]
Clutch Springs
AFAIK they would be genuine.piecutter wrote:Are they OEM stock springs?
Cheers .................. Blakey
