Color Codes - on EMO's Authority...CB77 Paint CodesEd Moore sent me color numbers listed below. Honda had four colors for the CB77 Black White Red Blue.
Bike silver is DuPont IMRON 45040U (Fenders and Side covers) Black is DuPont IMRON 99U. Red 6543UM Blue 63203UH Don't have a code for white (looks awful on the CB77)
Been doing some legwork on bike colors for my project, and since PPG is a little easier to get in my area, I have been checking on crossing paint codes for Red and Silver.
So, FWIW -- Red: EMO/LM likes Imron 6543UM, and this actually crosses to three different PPG codes, 71977, 71650, and 74359. The shop only had the chip for PPG 71650, and I compared it out in sunlight to the original part from my bike and it was a match, by all eyes in the area that saw it, including mine. The suggestion of Ditzler DPL71654K (from the Silver book?) crosses to PPG 71654, but it looked a little darker. It would probably look good on the bike, too, but I think the 71650 would be closer to stock. Side note -- I also compared the 71650 to some test shots I'd made using the Valspar Restoration Series Ford (tractor) red, and it is also very close match to this. So, if you want to get by a bit cheaper, the Valspar Resto Series is a good quality alkyd enamel, and it's available at Fleet Farm or Tractor Supply stores at about $8 a quart. Hardener is available, too. Hahnda has used this with great results on his Dream. Some will make the point that alkyd enamels are an older type of formulation, and won't hold up like the new urethanes, but it's still a great option depending on your budget. Guys on the tractor forums argue about this a lot! Silver: EMO's Imron 45040U crosses to PPG 33283, and while they didn't have a chip for this, the formulation is a very basic medium silver made up of black and silver flake, so should make a good match. There's my little bit of research, such as it is. Next time, if I remember, I'll check on the black and blue. Scottie '65 CL77 (in pieces right now...)
'70 CT70H '71 Yamaha R5B '77 Suzuki TC125
Ok,
Once again, FWIW, I checked with my PPG guy on the codes for the black and the blue. These are pretty generic numbers, and they cross to several codes, especially the black. Blue Imron 63203UH crosses to four different codes: 10419, 15958, 19126, and 19782. The main way to check these would be to check an original part against the paint chips, if they have them. The black Imron 99U crosses to many numbers, some of which aren't even black! The main PPG number it crosses to is PPG 120, a generic black. Check those chips! Scottie '65 CL77 (in pieces right now...)
I am restoring a 63 CA77, and had a perfect sample area on the back side of the battery cover insert to gauge the color. I had it tested, and it came back as a 1946 Chevy white.......makes sense? I shot some this afternoon and was pleased, its an off white, with a hint of almond color, just as the original. The DuPont # is 508IB (im not sure if its an "I" or a "L")
Paul
REDOn the PPG 71650, I found a powder coat color that is very very close and almost a perfect match.
I'm going to do one of my frames in this color and will post pics on my site eventually. Ping me if interested in the color and I will chase it down for you.
CB77 paintI had my CB77 painted at Honda as my friend works in the body shop.
The paint code for cloud silver is 08707-NH35M. 67' CB77
66’ CB77 65’ bomber 68’ hellcat
