																			 steven0356
						Post
								by steven0356 » Mon Feb 26, 2007 9:33 am
			I am trying to figure out what size jet I need for my 65 305 CA77.  Someone has put a 27 in there and I am having problems with my plugs fouling, so my guess is that the jets to big.
The bike mufflers have no baffle and I am using the air filter below.
Anyone wont to guess what size a jet I might need?
by the way what size is the stock jet?
[/img]
Thanks as always
Steve
																			 Hahnda
						Post
								by Hahnda » Mon Feb 26, 2007 10:30 am
			Are the plugs fouling while riding or idling?
Stock should be a 120 main and a 35 slow if I remember right.
I also run that same filter with open mufflers. I think I'm running a 125 main and stock slow. Also made an adjustment to the needle. BUT I am running rich at high speed. I need to check my main again and probably drop it down to a smaller size. I might be running a 130 right now can't remember. Anybody know what size main comes in the Keyster kit? I think that is what I am running.
																			 steven0356
						Post
								by steven0356 » Mon Feb 26, 2007 12:06 pm
			The plugs foul while riding.
Thanks Kevin
																			 Hahnda
						Post
								by Hahnda » Mon Feb 26, 2007 1:45 pm
			What are you running for plugs?
D8HA or similar?
does the bikes pull better when you let of the gas at full throttle?
																			 joeweir1
						Post
								by joeweir1 » Mon Feb 26, 2007 5:41 pm
			Try adjusting the main needle up one notch.Mine was fouling and that fixed mine.
						Post
								by LOUD MOUSE » Mon Feb 26, 2007 6:29 pm
			IGNITION. ..............lm
steven0356 wrote:The plugs foul while riding.
Thanks Kevin
																			 steven0356
						Post
								by steven0356 » Mon Feb 26, 2007 7:46 pm
			Hahnda wrote:What are you running for plugs?
D8HA or similar?
I will check it out but i think thats the plug.
before the plugs foul the bike runs like a bat out of hell. it starts right up and runs strong.  then I get about 5 miles down the road and one of the plugs goes bad. it has a black oily look to it but it smells like gas. Also the bike has very good compression and does not burn oil.
very frustrating
Steve
