Japan Meets Britain
Re: oil check
Post by G-Man » Thu Dec 18, 2014 6:31 pm
Gordon
Interesting. Did you ever try a pressure gauge on there or are you just checking for adequate flow?
GORDON BROWN wrote:Hello Everyone
Just a mention about what G-Man said, I made up a oil flow check point using a brake line banjo fitting with the end tapped for a bolt. Its mounted on the front R/H stud
( highest/furthest point).I milled a bit from the top cover and used the narrowest banjo I could find, also put a groove in the "fin" so it does not try to turn when torqueing the head.
It seemed a good idea on the parade / race bikes as sometimes it is unused for a long time. We turn it over using a starting engine with the plugs out ( you could just use the starter on a road machine ).
The main thing is you don't need to take the tension of the main head / cyl. studs, not exactly restoration stuff but you hardly notice it.
Hope this all makes sense.
Gordon
SAFOJ
GORDON BROWN
oil check
Post by GORDON BROWN » Fri Dec 19, 2014 5:42 pm
Hello
Graham, I have only used it to check for flow, though it would be easy enough to fit a gauge.
Is there any pressure in these things ? That said trying to get the bolt back in before the engine gets covered takes some doing.
Gordon
SAFOJ
Post by G-Man » Sat Dec 20, 2014 3:33 am
Gordon
Yes - I see the problem... :-) Maybe you need a radiator bleed valve on there..
I'm told that the pressure at high revs with the engine warm will only be 5-6psi and so low that you cannot measure it at idle. Comforting to know that it gets to the valve gear though.
Thanks for the info - have a great Christmas!
Vince Lupo
Post by Vince Lupo » Tue Feb 10, 2015 9:52 am
Vincent Black Shadow, stand aside.....
Wheels2015-1 by Vince.Lupo, on Flickr
Wheels2015-2 by Vince.Lupo, on Flickr
ahenthus
Post by ahenthus » Wed Feb 11, 2015 9:44 am
Looks great Vince. Did you do the painting and striping?
66 CL77
laverda
Post by laverda » Wed Feb 11, 2015 9:48 am
Hi Vince where did you get the bacon slicers from
Richard UK
Vince Lupo
Post by Vince Lupo » Wed Feb 11, 2015 10:51 am
ahenthus wrote:Looks great Vince. Did you do the painting and striping?
Oh no - I have nowhere near that kind of talent. That is the domain of my good friend Lee Hulteng. He did the 'roadrunner' on my chainguard, plus my gas tank, and the red coachlines on the rims that were on there previously. Plus he made my chainguard. So he is one talented fellow!
