Clutch Cable Routing for 305 Dream
Gregg
Post by Gregg » Sun Mar 25, 2007 7:08 am
I'm re-assembling my bike after a restoration and am having a senior's moment. I can't recall the proper routing of the clutch cable from the case up to the handlebars. I believe it goes thru one of the holes in the pressed frame and out a hole on the opposite side. Can anyone help. Thanks
Gregg
4shorts
Post by 4shorts » Fri Mar 30, 2007 8:48 am
When I installed mine I ran my clutch cable up from the engine and along the right side of the frame, went up across the front of steering bearing tube and out through the hole in the left fork hole and up to the lever. Worked perfectly for mine.
