Vacuum lines and vents?
carlluvscorinne
Post by carlluvscorinne » Fri Apr 06, 2007 10:02 pm
Hi All:
I am putting back together a 1964 CB77 Superhawk, and I am wondering where the lines from the vent fitting in the top of the cylinder head cover, the two vent fittings next to the carbs, and the one vent fitting on the air filter go to, connect??? Any help would be greatly appreciated.
Thanx, Carl
Re: Vacuum lines and vents?
Post by LOUD MOUSE » Sat Apr 07, 2007 5:47 am
The top vent passes to the right of the left carb and through the slot in the case cover and 1/4 inch out of the hole behind the drive sprocket.
The 2 vents attach to a plastic "Y" then to the tube on the right side air cleaner. ...lm
carlluvscorinne wrote:Hi All:
Thanx, Carl
carlluvscorinne
Post by carlluvscorinne » Sat Apr 07, 2007 9:55 am
Awesome...Thank you very much, that was not at all were I invisioned them going. Carl
ggray
Vent tubes
Post by ggray » Sat Apr 07, 2007 10:01 am
Carl, You read my mind for a question and Ed provided the appropriate answer, as usual. Thanks to both.
Gary
'65 CL77 Owner
