I've freed the piston in the basket case I now own (it sat outside for years). Now of course the cylinders need bored.
The mechs at the local shop (established for decades - lots of old stuff) tell me a .5mm overbore will clean up the affected cylinder. They can find no replacement pistons/rings for me, though. In fact, they felt I'd have a really hard time finding a piston and rings for a CB77...
However, there are far too many posts about seized engines on here for pistons/rings to be THAT hard to get.
For example, I see on Ebay +5.mm piston/ring kits mfgd by WISECO for $239.00. I also saw a +.75mm kit for $150.
Plus I read here about putting CB350 pistons in these engines.
Having learned all of this, my questions are the following:
1.) Bored vs 350: what all do I have to do for the 350 piston-option to work, and how much will it stand to run me? $$
2a.) The +.75mm kit I mentioned above is for a CL77. Same difference, right?
2b.) The kit has no wrist pins. Will stock 305 ones work?
2c.) I'm leaning toward this option. An overbore of +.75mm is safe, and will in no way affect the longevity of the engine will it?
3.) Other places to get oversized pistons and rings for a CB77?
Thanks,
Andy
CB77 - Boring Nec, Best Option/Size for Parts?
Re: CB77 - Boring Nec, Best Option/Size for Parts?
I have the CB/CL77 .75 pistons and rings and the C/CA 77 pistons which will raise the compression a small amount and cost a lot less.
The pins will work if they are not warn out. ..........lm
305explr wrote:I've freed the piston in the basket case I now own (it sat outside for years). Now of course the cylinders need bored.
Thanks,
Andy
Thanks for the reply. If I'm understanding you correctly, you have in your possession BOTH the +.75mm CB/CL77 pistons AND the +.75mm CA77 pistons.
And the CA77 pistons are cheaper. (Are you selling them?)
Lastly, the CA77 pistons will raise the compression -- a good thing, I'm thinking, but does it necessitate other changes?
O/S pistons
I just got a set of the Wisco pistons, and they are beautiful. Forged, cut down skirts, and a complete package for doing your top end. That's all I'm going to use from now on. Just my 2cents. Davomoto
65ShelbyClone
